teryjck
I have a 700sx,it starts good,but i have to choke it quite a bit during warmup is this normal for this motor,it seams to bog untill it warms up.major cold blooded.had the carbs apart.looks clean to me,
Ron Boals
Slow warmup
I have 4 of these sleds and that is pretty much the case. I just picked up a 98 SRX 700 and it seems even worse. I have been fou1ing plugs like crazy so far this year and discovered that the plug caps seem to go bad, corrosion or whatever they don't test at 5Kohms hope I have it worked out as I am on my second box of 10.
Hebi
My '01 Poo 600 XC is the same way. Youve gotta play with the throttle and choke to keep it running. Even after 5 minutes of that it will still backfire occasionly for the first 5 miles.
Its kinda sad, my old Phazer started and ran 10 times better than this XC. And my Phazer was 11 years older!
Hebi
Hebi
sockeyerun
Test Dummy
Have you read the thread on proper warm up procedure. Lots of good info there.
the sx is cold hearted no thermostat. read the thread soc refered you too....its all there about the sx's
seanmurphy26
that weird i must be the only one without a problem i have the 98 700 sx. works fine for me starts 3rd pull and stays running on its own
