yamialltheway
I am looking to buy a new sled, I trail ride most of the time but i ditch a few times a year. I am looking to spend about $2500
a viper or sxr will do fine..
SRX for Racing
Viper/SX-r for trail/ditch riding
Maybe a Viper with an extension to 136" long track/ tunnel. Lots of good deals to be found. Vipers will run forever with proper maintenance.
SXR or Viper...
tedgoesfast
sxr for sure
I would look for a Venom[they are 600s]. They are often over looked, can easily be turned into a 700, relatively light, Viper look and ride...red head[SXR type engine] simplicity and reliability.
JM.02c
Bob
JM.02c
Bob
yamialltheway
Thanks for the Replys, i think i am going to start look for a viper or Venom. Can i have some more info on a venom, Thanks.
a lot of vipers have been going down lately..crank issues/rod bearings...check into that first..
Yamaha Venom:
-built from 2004 - 2006
-only avail as 121"
-600cc tripple,single pipe, non power valve["red head"] engine the same as SXR and Mountain Max
-high output stator
-available with reverse and electric start
-looks like a Viper
-same suspension travel as Viper
-at least 10lbs lighter then Viper, advertised as 489lbs/ER at 515lbs dry weight
Try Googling for more info
Bob
-only avail as 121"
-high output stator
-looks like a Viper
Bob
burnoutink
I got the Ol' Red head and I love it, extremely solid engine!!!
never let me down!!!
bluebandit98
x2 had a few of them
s10mike
anything with a redhead. not much faith in vipers.
vibeguy
- Feb 5, 2006
The Mtn. Max engine is much better than the Viper engine. JMO
Viper engine is as good as anything Yamaha ever made.....IF..... you fix the head issue.
mattyg1405
THE 500 CC????? THATS LIKE COMPARING APPLES TO ORANGESvibeguy said:The Mtn. Max engine is much better than the Viper engine. JMO
ridergonwild5692
i dont understand why u guys are so afraid with vipers. they are awesome machines. you guys only here the bad about vipers but never the good....
TopGunnSrx
SRX with suspension mods!
super1c
Super Moderator
Im into vipers for sure. I tried to get a venom for my daughter but hard to find and way too high in price. At least a grand more then most vipers. The few venoms i found around here were about 3000: you can get a 2004 viper for about 2300. Chris
TopGunnSrx said:SRX with suspension mods!
X2 - A Viper is still a Viper, but a Viperized SRX is the best of both... IMO.
