The tech pages show a veiw of the float as it is held at a 45degree angle.
My ? is where do I measure from??, because there is a 2 to 3mm step in the bottom of the float that doesn't show up in the diagram.
There is a flat bottom section then the 2 to 3 mm offset to another flat bottom section that then curves into the round front of the float.
I hope you can get what i'm trying to say...Thanks.
I set my floats off the tange on the bottom of the float when upside down and to the bowl mount surface.
by the tange, do you mean where the metal part of the float is molded into the float material???
yes.....thats what I mean.
