tallest lug possible with 8 tooth drivers?
I just took off a 1.75 with 9 tooth drivers and still had room, so a 2" paddle should fit with 8 tooth drivers
you cleared a 1.75 track with the 9 tooth drivers? maybe I won't have to change drivers then. I was hoping to use a 1.325 lug with some chisels for snow drags.
I replaced that 1.75 track a .5 trail track 1.2 chisels and had to put extra tunnels protectors so they wont hit any where I have 1/2 inch clearance the way it is now.
If I were you I would just change the drivers to 8 for the extra clearance just to be on the safe side, you never know how much you track will ballon or rachet when under load
i know guys who have studded 1.25 tracks with 8 tooth drivers, but i don't know if the longer studs on a 1.375 will still have enough clearance or not. better find someone who's tryed it before buying anything.
I am going to be pulling the front and rear coolers out of the tunnel.
