Styles211
I have a 99 Srx, Last year I was running br9 ecs plugs but found that I was foueling them all the time so under advise from someone I changed to br9 eya and never had a problem again.I was recentely reading a forum here that didnt recommend running them so I switched back to the ecs's again but after a short ride today foueled one again.I dont know what to do?
Styles
Styles
The pluge are fouling while riding?I've seen them do it when warming the engine up if too much choke is used but once a system of only using the choke enough to keep the engine running until it will run on its own is adopted they will usually never foul if your careful.
Styles211
It happened when I was sitting at a stop sign,I was driving slow the whole time because my 4 yr old daughter was with me. It was good and warm and there was no choke involved.
Brad
- May 23, 2003
marc i think that you might be jetted to rich should get a hold of doug
Styles211
Thanks Brad!
I will give him a call and see what he has to say.
Styles
Styles
