600 head on 700 cylinders
vinc600triple
gaspé,QC
if I put 700 cylinders and pistons with my 600 head can I still keep my head gasket removed ? or it will have too much compression ?
I think it will have to much compression as the 700 cylinders are a larger bore. I don't think that head will even work with 700 cylinders unless machined to fit with the 700 cyls.
did that on my sx 700 cylinder wit 600 head and thin head gasket run fine till i jetted to lean n blew mag side piston and cylinder lol jus make sure run 91 octane fuel
youll definitely need to open up the chamber to the bore size of the 700 or it wont run very long.
