86 Phazer fuel issue
phazer35
SLC UT
I have an 86 phazer and I am not getting fuel to the carbs. I have been through just about everything I can think of and I cant find the issue. I have tried a different fuel pump, replaced the fuel lines, checked the tank line for any clogged lines. Nothing. I am at a loss. The fuel lines will partially fill up when I yank on the pull starter but the fuel will sort of pump a little but not all the way to the carbs. The sled was runing fine but I had to pull the motor out to fix a steering issue and when I put it back in... no more. Any ideas??
Anyone? I'm getting really aggrivated with this sled as it used to run PERFECT. HELP!!!!!!
Did you prime the fuel pump?
Had the same issue with my 93 Phazer after replacing the motor last week.
I put a syringe of gas down each plug hole and started it.
Had to do this about 6 or more times before it eventually pumped enough gas to continue running.
