snoprokidf6
does anyone have any tips for removing the lower radius arms, i'm having trouble removing the bolt that connects the lower arm to the bulk head. also does anyone have the measurements for the 4 holes in the bulk head that hold the arms to it, i need center for all 4 holes laterally and vertically to eachother.
If memory serves me correctly, I put a ratchet under the engine and used a wrench on the front end. That way you can just do the ratchet action with your wrench cause the ratchet wont fit on the front. I dont have a ratchet style wrench.
super1c
Super Moderator
They are a pain for sure. I was able to get out one as described above. The other was rusted into the radius rod collar. It will spin but wont back out of the collar. I had to cut the bolt from under the sled then pound the rest out of the collar. was not easy. I tried holding the collar with vice grips and used heat but no luck. Just melted the belly pan, woops. Chris
