Clutching
01sxr700
Thunder Bay, On.Ca.
I presently was running a 700SXR with a 15 x 144 x 1.5" track with 2001 MM gearing, clutching and 8 tooth drivers. Due to stabbing the track I am now going to install a 16 x 144 x 2" track. Do you think that I will need to change the clutching and if so to what?
If it worked good for you before, I wouldn't change anything. You're adding a little extra weight, but not much. I'd be more worried about stabbing the new one if it's happened to you already.
