gearing components
snoprokidf6
Lee Center, NY
tried searching but no such luck. can i throw a gear from an apex, nytro, mtn max or something older onto a viper shaft, i'm looking around for a 21 tooth top gear for my viper and i've found a bunch but none are for a viper, i've looked up the part numbers and they do not match, two letters are different in the part number sequence, has anyone tried this?
I thought as far as the SRX's gears they had to be from a 2000 on up model as that is when it got the Hyvo set up.
