Thanks Ron. Looking at the new Winderosa seals I have, they do not have any grooves or ridges, they are smooth on the sides. I have everything off the lower end, but splitting the cases seems to come with a host of potential problems. Pressing the crankshaft out, heating and pulling bearings, etc. I did buy a Clymers manual, although it does not cover single cylinder teardown.(38.00 waste, I think) If I have to, I have to, although if I can avoid it, I will. I was going to possibly replace the bearings too, if I do have to split, but 90.00 for (2) bearings seems unreasonable. Not only that, you still can't do the rod bearing, so ?????? Anyway, any other tips on this rebuild would be apprieciated. Thanks in advance....
