91Phazer2011
i was wondering what i could do to make my 91 phazer jump off the line, clutch wise.. cause as of right now i have 85f ramps and a black spring..? could i do steeper ramps, with a different sping?. also when cleaning my clutch there is 3 plastic pucks that the spider slide in and out on.. they have dried glease on them, causing a bind.. is it wise to put some greese on them,to slide better, if so what kind?.. and what other parts should i clean on them.. thanks in advance.. all comments appreciated.. if you have an idea, i would like to hear it thanks. Corey
8vo fan
No supossed to use grease anywhere on the clutches, use dry slide instead.
