Not getting gas to the Carbs
d4laseck
Michigan
I have a 2001 SRX and i am not getting gas to the Carbs. The bowls are completely dry. What do i need to check for or replace?
Tank has gas in it right? I would start at fuel pump. Pull inlet line to see if you have fuel there. if yes i would think bad pump. If no then pull line of elbow on cowl. If yes then you have plug in line, if no i would suspect blockage in tank. You could try back flowing air from pump to tank. I recomend having gas cap off for this. Tank has a vent but may not handle alot of air being forced in. The pump is driven off a vacum line below center carb. Could be a bad/split in hose as opposed to bad pump. As always just my opinion.
