New Bushing Installed Primary Clutch How Tight?
SRX_700
Toronto
How tight should it be going up and down the shaft? It seems very snug and takes some pressure to get it to go up and down. If I don't align the "x"'s it is a little easier. Could be spider shaft it bent and/or moveable sheave opening is distorted.
Yes it is, installed by a Yamaha technician. It appears when I assemble the cap and spring, there isn't any binding anymore... Only binds when the spring is not present.
