2001SRX=Fast
How do you know when one powervalve isnt working?
tripple_tripple01
power valve
whats it doing, mine mite be acting the same way, like not hitting the proper rpms?
2001SRX=Fast
yah it seems to be lossing a bit of power... it felt weird when i got on it and road it today.. It wasnt sputtering or anything out of the ordinary.. it felt like it didnt have that lil extra boost that it usually has.
Remove the powervalves from the housing. See if the cables have pulled thru the end of the power valves & make sure cables are not stretched. You have been checking & cleaning powervalves regularily???
2001SRX=Fast
yes i clean my p.v's every 1000kms
excel V
- Apr 8, 2004
If your P. Valves become stuck, they stick in the open position. The stuck valves are noticable at low RPM. The engine will have a slight bog. At higher RPM's ther is no noticable differnce because the valve would be in there open position anyway.
tripple_tripple01
power valves
wel im gonna pull mine apart wednesday and let ya know, sounds like we mite be having the same problem? are you hitting 8500? im only hitting about 8100 on my tach, but like i said, when i cleaned mine this fall i noticed that one end looked rough, and im hoping that all it is. anyone know a quick fix if it is pulled threw???? thanx.....jim
Vmaxsxt
Not sure but I would think if the power valves were sticking they would be in the closed position,otherwise why would srx's be known for pulling the cables through the end of the valve.If they were stuck open the servo motor wouldn't be pulling on the cable would it? Someone please step in and correct me if I'm wrong.
I agree Vmax, one of my cables pulled through with the valve in the down position. I would think that the easier way to check them would be to pull the cover off the PV motor drop the RPM to below 900 and see if there's tension on all the cables. If any are pulled through they will be slack.
tripple_tripple01
good call yamahay, very esay way to check. im just wondering how im gonna fix that now tha tit is pulled threw???
You gotta buy a new powervalve. Check to see cable ain,t frayed too!
Rambunctious
after 3300 miles ( bought sled with 2700 mile) i found that my gap (when adjusting) was about 1/4 inch!!! i dialed them in to 1/8inch using a 1/8"drill as suggested on the board
is it common for the cables to stretch and require that much adjustment?
btw.all cable ends are good now as i had to replace one power valve last spring.
ramb
ramb
