95 vmax 600 twin...stud let go and ripped the front exchanger...is there enough cooling with the tunnel and rear exchangers to bypass the front?
amazza76 said:95 vmax 600 twin...stud let go and ripped the front exchanger...is there enough cooling with the tunnel and rear exchangers to bypass the front?
mrviper700 said:As already mentioned the front does most of the cooling work,so the answer is 'no". I can tell you I have repaired a few yamaha sleds over the years by removing the skidframe and track, drain the collant and flush out ssystem very well to remove antifreeze. Then stand the sled up on the rear bumper and lean it up against the wall. wash the area well with brake clean and compressed air, then tig weld the hole. It will save ALOT of work changing it out.
