foam inserts
snoprokidf6
Lee Center, NY
tried to search but no luck, does anyone know where to get a course foam to insert into the viper air tracts on the sides of the headlight? something that doesn't restrict air too much but stops most if not all the snow/water
i maybe going this route, the viper has two ducts (as some may know) but i recently figured out they route down directly to the brake rotor and belt guard, i was thinkin if drilling a hole in each, about 1in diameter to get fresh cool air to the air box i may be buying some of the pre filter material and hot gluing it to the front of the duct pieces
