PTO end Crank Bearings..1983 540SRV ?
Mount Albert , Ont
Due to being lazy , I smoked the pto side of my 93 VK540II...the crankseal
was blown out and even the oil pump rubber door was missing.Took 3
seasons but that was just a few hundred miles .
The orig engine is full of Almn and decided to pickup an other . Turned out
to be a "SA535" in 40,000 sn range , which could be the 83 SRV....
IS THat correct ???
IT's last owner had holed pto piston and had alm in crank as well, so I
want to install new brgs,,and it had OK cylinders
If so , I checked boats.net and it shows the pto side obs. but fits back
in the 433 to GPX models and forward in 440's and 535....
My orig 93 shows brgs avail , but diff # , but same seals, spacer between
them , same crankcases, same locating 1/2 ring in outer...WILL they fit ?
Sorry ..I'm at home and dialup so I don't have the part numbers here.
It is hard to find a good "tow truck" VK in southern Ont or I might have
just parted out the sled,,and already had bought new pistons before finding
the Almn in this engine.
What are you guys using for brgs ??
I will post the Yam brg number later unless someone already knows the
answer I need...
Ron
Check if the differrence is in bearing locking pins. Other bearing has hole for pin and other has pin on it. You can use both with small mod.
Thanks for the replies , Reimond and Vmax540
The chart has very limited PTO end brgs but I will check
a parts catalog to see if Vmax540 uses the same brg
as either ..
If it's just a pin issue I expect the casing can be modified
Ron
the vmx540 pto end brg is diff than any shown for SR and
is similar to bigger engine up to 600...
Diff seal , spacer , crankcase ,etc as well.
The 91 to 05 VK brg is looking more promising on paper
and was hoping for someone that has done the job....
shows fitting these models for the older engine
Parts Not Available
Part Number Variations
93306-30625-00
93306 30625 00
933063062500
Description
--- BEARING, BEARING (B6306 SPECIAL), BEARING (B6306)(93306-30612), BEARING (B6306) (93306-30613)
This Yamaha 93306-30625-00 BEARING part is also used on these models and components:
1974 GPX338F CRANK - PISTON GPX338F - GPX433F
1974 GPX433F CRANK - PISTON GPX338F - GPX433F
1975 GPX338G CRANK - PISTON
1975 GPX433G CRANK - PISTON
1976 EX340 CRANK-PISTON
1976 EX440 CRANK-PISTON
1976 SRX340 CRANK - PISTON
1976 SRX440 CRANK - PISTON
1977 EX340A CRANK - PISTON
1977 EX340A CRANK-PISTON
1977 EX440A CRANK - PISTON
1977 EX440A CRANK-PISTON
1978 EX340B CRANK - PISTON
1978 EX440B CRANK - PISTON
1979 EC540C CRANKSHAFT - PISTON EC540C
1979 EX440C CRANK-PISTON
1980 EC540D CRANKSHAFT - PISTON EC540D
1980 EX440D CRANKSHAFT - PISTON
1980 SR540D CRANKSHAFT - PISTON SR540D-E
1980 SR540D CRANKSHAFT--PISTON (F)
1980 SS440D CRANKSHAFT
1981 EX440E CRANKSHAFT-PISTON
1981 SR540E CRANKSHAFT--PISTON (F)
1981 SS440E CRANKSHAFT - PISTON
1982 SR540F CRANKSHAFT--PISTON (F)
1982 SR540F CRANKSHAFT-PISTON SR540F
1982 SS440F CRANKSHAFT - PISTON
1982 SS440F CRANKSHAFT-PISTON
1983 SR540G CRANKSHAFT PISTON
1983 SS440G CRANKSHAFT - PISTON
1983 SS440G CRANKSHAFT-PISTON
1984 SR540H - SRV CRANKSHAFT - PISTON
1984 SS440H - SS440 CRANKSHAFT - PISTON
1985 SR540J - SRV CRANKSHAFT - PISTON
1985 SS440J - SS440 CRANKSHAFT - PISTON
1985 XL540J - XLV CRANKSHAFT - PISTON
1986 XL540K - XLV CRANKSHAFT - PISTON
1987 SR540L - SRV CRANKSHAFT - PISTON
1987 XL540L - XLV CRANKSHAFT - PISTON
1988 SR540M - SRV CRANKSHAFT - PISTON
1988 XL540M - XLV CRANKSHAFT - PISTON
1989 SR540N - SRV CRANKSHAFT - PISTON
1989 XL540N - XLV CRANKSHAFT - PISTON
1990 SR540P - SRV CRANKSHAFT - PISTON
1990 XL540P - XLV CRANKSHAFT - PISTON
1991 SR540R - SRV CRANKSHAFT PISTON
1991 SR540RSR CRANKSHAFT - PISTON
I need to get both cranks home and do some
serious measuring as reimond suggests
Thanks for now
Ron
I have use that 93306-30625 (still available) on SRX440 engines. Only difference for stock bearing is pin vs. hole.
Reimond.
I did a bit of goggling and found a few dealers with them
forsale , but a number of other sites showing NLA...
I have a call into local dealer to check it out for me ..
Most of the dealers with website sale are in USA and
sometimes the brokerage can be ugly unless sent by mail.
Ron
thanks for the replies.....Called my local Yam dealer
and had the parts 2 days later .....Strange that so many
diff dealer sites were wrong....
The orig 93 engine injected oil into the fuel line ahead
of the fuel pump.....and the older engine into the manifold..
I sort of prefer the manifold,,,,any reason to return to
the orig design , into the fuel line ??
thanks
Ron
