340 exciter?
rich
LeRoy MI
Hello, has anyone ever put 2 carbs on a 77 340 exciter? I know they have the 440 but have not seen anything on a 340. Also does anyone know if the exciter and the enticer motors are the same? Thanks Rich.
Most race groups don't allow putting two carbs on sleds that
came with one in stock and super stock classes. You will need to make
sure you can do that first if used for racing. Single carb is much simpler
set up and the sled still really flies. Pretty sure the enticer motor is
different than the 340 exciter.
Enticer 340's are different.
It's been awhile but if I remember right carbs/boots off of a Polaris TX 340 are a direct bolt on to the Yamaha Exciter 340 cylinders. The TX's used 32? or 34?mm round slide Mics on them. Jetting should be close I would think.
opsled
