keyway sx viper
yamahadanik
chateauguay qc
does puting an advance keyway on a stock pipe sx viper whit a port match job and a little porting will gave more power? How many degres does my keyway need to have?
Would try out with stock settings first, ,,,,,,,,,should have enough timing to run desired rpm........then go from there..........
The stock Vipers already run a lot of timing advance. IMO...I would not advance the timing any further or you could end up with reliability problems resulting from detonation.
JM.02c
Bob
