02 viper w/ 136" question
BRAAAPPP420
new york
ok so over the summer i put an 04 ski doo 136" sc3 10 suspension into my viper. i also purchased a brand new 1.75 camoplast backcountry track and ii put the 8 tooth drivers on it also. i didnt gear but i know i should but im not sure how many teeth top or bottom. im mainly looking to know what i could do to stand this damn sled on end for a good distance with out having to do expensive engine work or pipes. i have a rumble pack and the limiter straps are very loose. if anyone would know what the most reasonable and inexpensive mods could be please let me know what i could do. thanks, dave O
136 part is your problem escpcially the sc3. one thing u can do with the sc3 is you can take the rubber stopper on the rail loosen it and flip it up gives you like an inch more of transfer and works good too.
Are you simply wanting to pull wheelies or actually accelerate as quickly as possible? Traction and full weight transfer with no limiters will pull wheelies easily.
