SRX7
Im getting a little bit of ski lift.Alot actually.I noticed that the straps are set to 30mm.The sled transfers well maybe to well just after take off.Sled is all stock, shocks are set to std.Equal gap from top to bottom on the transfer rods.Im thinking of stiffening the front Ohlins springs or stiffening the dampening setting on the clicker.
What do you think?
I would like to get it to corner flatter.
2000 SRX.
What do you think?
2000 SRX.
SRX7
Any thoughts?
I wouldn't puul up the limiters any more. Check your front end set in. Lift the front of the sled until the skis are just barely touching, and measure the bumper height. Then let it down compress the front shocks by pushing the front down, and measure that. You should have 15 to 20% sag on a srx. if you have more than that then tighten the ski springs some. you may have to add some rear spring after adding front spring. Maxdlx
SRX7
Adjusting the dampening for the Ohlins really helped.
