tripple pipes, holtzman atacc, clucthing and gearing
dallasditt
edmonton
i got a 2004 sxviper mountain i want to tripple pipe, what is the best pipes? i would like to get holtzman atacc also will it work with the pipes? do i have to do anything to make it work? also what is the best clutching and gearing setup for a set of pipes? i am more of a field rider but with some big hills but not so much mountain. thanks
The ATAAC works really well with triple pipes. I use it with my SLP triple pipes. High recommended. With the ATAAC, you jet for the lowest altitude/ lowest temps you plan to ride. The ATAAC then leans out things automatically. Closest thing you can get EFI on a carbed sled.
My sled is a 03 Mt Viper. Stock gearing. I also run a Heel Clicker 40-10 kit with the red spring. The recipe I'm running is very similar to the one prescribed by Heel Clicker in the manual. You have to tune accordingly for your conditions tho.
I ride like you -- lots of hills, clear cuts -- flat land off trail riding. I'm at about 1,000 to 1,500 feet above sea level. Not out west very often.
