2001 MM larger heat exhcanger?
norwegian
Well-known member
norway
The 2001 MM has a small tube/bar like rear heat exchanger that goes across the tunnel at the rear. I've seen a larger/broader bar like heat exchanger on a 2003 rx-1 M that was added afterwards. What's the part number of this exchanger? Where can I find a pic, for comparison?
I think he'll need that in the spring because it' rock hard on the river then.
thanks
I've seen some guys adding that heat exchange, but they had to add some support to it since it has an angle on it and does not lay flat against the tunnel, which is preferable on the mountainmax since it does not have the "wall" at the end of the tunnel to rest against like the srx does.
I put the SRX heatx in my 01 MM, didnt have to modify anything. I have extended the tunnel out to fit a 151 in there. But no probs for install and really cools down a triple piped MM.
