Can anyone help me with how I get at the bolts holding the oil pump on? I can't get at the allen head bolts which attach it to the engine. I have the carb's out of the way. The problem is I can't get at the pump good enough to get the 2 allen head bolts out. It's too tight. The steering column and a motor mount are in the way. I even tried loosening the motor mounts to try and get a little more play. There must be a easier way. Help!!!!!!!!!!!!!!!!!
Smurf
Smurf
Remove the motor mount.
