HAUCK adjustable weights question?
kking32
moncton canada
HAUCK LAUNCH WEIGHTS question?
just picked up some adjustable primary LAUNCH weights, with screws etc, does anyone have any experience with this? what would be a good starting point on my stock 99 srx 700? i couldn't pass up on the deal for $60, i'm running 8bu 20 now and find them better then stock, i'm looking for trail aggressive and 660 drag etc, thanks
I ran the Hauck "T" adjustable weights in snow drags many years ago. It may be a starting point for you but probably would not work well with studs or on pavement and will need"tweaking" for your application.
Heres what I used.
Bare T weight...46.5 grams
screw in tip........4.8
screw in centre...3.2
Total.................54.5 grams
Secondary Helix....... Dalton 53/47
Secondary Spring..... Yamaha Green 60 wrap
Primary Spring.......Yamaha: Yellow/Green/Yellow
Gearing.......21/40 = 1.90:1
stock 9 tooth drivers
Worked for Me:
Bob
i run them in my 99 srx works great 55.5 grains heavy on the tips i run with hauck red spring j helix with silver spring very aggressive hauck is very helpfull if you call them as well
I have Haucks #4 kit and it works great. I`ve heard bad things about Benders kits, but Hauck is on point when it comes to clutching these SRXs.
Launch Weights. HAUCK
the weights actually are the hauck launch weights , i saw them on their site for $250 plus tax and shipping? wow not cheap, i guess 60 bucks was a good deal, each weight has two sections, anyone using them?
