pipe+viper=bada**
I wana put a 1.5 inch track on but i need to know if i need to put in a 8 tooth sproket in. plz help
Waters88
Someone will correct me if I am wrong, but I am fairly sure that for a 1.5" lug you will need to go to an 8 tooth driver, so yes, you are correct.
super1c
Super Moderator
You can run a 1.5 track but you will have to remove the front heat exchanger protectors and tunnel protectors and you will still have a bit of rubbing at times. Best to go with 8 tooth drivers
Also. If you decide to go through with the 8 tooth driver swap remember to also make the correct gear swap in the chain case. You'll probobly have to go down one tooth on the top sprocket.
livewire_101proof
keep in mind with 8 tooth you loose power due to bending the track around a tighter cuve, and it is also alot easier to jump the track if you hook up hard or anything like that. i would consider atiratchet drives if you do it. if your really lookin for a summer project keep your eyes out for a drop and rolled chaincase instead, then you could keep the bigger drives and your protectors. That will take a little more work, not sure how much mechanics you are willing to put into it, not to mention probably a bit more money involved.
