tippmannator
couldn't find the answer i was looking for with a search, so ill ask. i know the 06 apex bars will bolt right to the srx, my question is about all the hardware. will the brake and throttle fit onto the bar? what about the hand warmers? i know the wiring is different, but i dont know the first thing about rewiring something, so if someone has done this allready and can help me out at all that would be awsome!! and one more thing, im running a 4 inch risor on the stock bars, how much height will i lose between the srx bar and the apex bar??
thanks guys!!
thanks guys!!
Check my sig below. You will need to copy the link into your browser. This is what I did to my Viper. Should be the same for your Srx.
Could you move this to the Tech section? Might be easier to find for those doing this mod. Thanks
I moved the link that I posted into the Tech Questions, is that what you meant?
tippmannator
i guess i didnt look hard enough
are the apex bars straitor then the srx bars???
are the apex bars straitor then the srx bars???tippmannator said:i guess i didnt look hard enoughare the apex bars straitor then the srx bars???
Yep. In post #2 it shows the diff between the bars.
livewire_101proof
would like to add that if you have bars from an 06 they have the replacable hook ends instead of the bars being curled at the end like the ones in the pics
livewire_101proof said:would like to add that if you have bars from an 06 they have the replacable hook ends instead of the bars being curled at the end like the ones in the pics
Yep. Makes it much easier to install the throttle block with the removeable hooks. I had 06 bars and found that my ring and pinky fingers got cold with my driving style. The 07's seem to be warmer with having the heated hooks.
tippmannator
thanks for the help guys!!
