How does the seat come off on an srx
super1c
Super Moderator
They should pretty much all be the same. In your seat trunk their should be a nut on each side. Just unbolt and it will lift right off. The front has tab that slide under gas tank so give it a slight pull back after lifting off the bolts in the trunk. Then just unpug your harness.
musselman
Make sure you undo the snaps and bungee at the front too.
