Hey guys, I was doing new rings and when I separated one of the cylinders water ran into the crank case. I siphoned out what I could. Should I be concerned?
that is probably some anti freeze that dripped in there.Get some fogging oil and spray it in the crankcase area and rotate.Put lots of it in there.When you start your sled later..run her good and hot to get ride of it.
use a shop vac with a small hose taped on the end of it.
there is a bolt in the pump cover with a washer under it, back that one out and it will drain the sled below the cylinders.
