panthers06232
My 98 srx will not jump out of the whole at all where are the limiter straps and how do i adjust them back to make this thing wheelie
more of it is adjusting your transfer rods for max transfer.This couples the skid more and losen the front straps for more lift.Straps are in the front cross member were the the front skid shock mounts to..
just a note...you may not have adjustable transfer rods..then remove the white washer on top or put a thinner one in..ALSO you won't have much steering if your front end is always up during acceleration...been there done that...
panthers06232
this sled just seems so front heavy and no wieght in the rear will it help to adjust the ohlins shocks if so how do i do that
if you remove the shocks you will lighten front end some...lol
you have to play with your transfer..I can get my SRX out of the hole with ski's barely lifting or adjust full transfer and my ski's are 2 to 3 feet in the air....
staggs65
it sounds like you need to set up your suspension properly. look up betheviper in the member list. in his sig there are links for tightening and setting up your suspension. there is also info in the tech faq section including the proaction tuning video
be carefull don't loosen your straps to much, the front of your slid rails will actually come in contact with the track and snap them off tairring your track into. Speaking from experience
panthers06232
i see two white washers a smaller one and a bigger one there not even tight i can spin both with my fingers which one do i take off and how does it come off there are toward the rear of the sled thats the only two i can find on this thing
panthers06232
thank you that will help a lot
livewire_101proof
X2 on bethevipers setup, will make a whole new sled for u if it isn't setup right. Any of his posts have links under them for the setup info
