Live2Ride
- Nov 24, 2003
Was wondering if anyone knows the torque specs for the motor bolts. I need to know so when I put the motor back together. I would also like to know the torque specs for the bolts on the jug and for the allen head bolts on the power valves.
How do I bleed the anti freeze system
Thanks guys you have been very helpful....
see the Tech Area....there are some specs in there on the jugs and heads settings....most of those other bolts are 7 to 10 ftlbs. Bleed the system with the bleeder under the back seat and in the front of the engine....rear is where all the air will be anyway....reed in the Tech section on the head gasket mod.
