srx riser
stealther27
Jefferson, WI
hello all, in the last couple weeks started doing a little work on my sled. Last year I put on a 2 in. riser on my srx but this past spring bought a rox riser adjustable one which raises I believe 3-6 in. I already got a mountain rx1 throttle cable and am wondering what else i need Im guessing a longer brake and what about oil cable?
Mysledblows said:
Brake line, Oil cable, figure out the parking brake, and might have to extend the wiring.
X2
i raised my 02 srx 4" and did not need to extend the wiring, but if i went higher i would have to.
also the steering posts have been known to snap on the srx with risers. it was worse on the 98-99s. but i know of a few 00-02 with the updated posts that have snapped too. if you take a piece of 1/2" pipe and sand it down with a flap wheel enough to slide into the post and weld it in it fixes this.
