TRUE BLUE SINCE 1980
It only took 18 years for our Polaris, riding buddy to come over to " TEAM BLUE"
We are going to try to put him on an 03 or 04 Viper. My other buddy and I had SXR"s and now are on 4-strokes. So, we have no working knowlege of these sleds. What do we need to do pre-season to one of these sleds.
From what i have read the head gasket needs changed , the track has issues and the power valves need some attention.
Any info will really help !
Also I am hoping the Viper is "stronger" than an SXR ??
......RIDE ON !!
......RIDE ON !!
staggs65
clean the carbs, check your w arm. look into a rear heat exchanger. besides what you mentioned pretty much the normal sled pm
averagesleder
Great sled, clean the carbs and powervalves set them to spec.
Yamahahoo
Yes the viper is "stronger" than the SXR for sure!
super1c
Super Moderator
Other than tearing the engine down i have done everything else you can do on a viper in this post. Even the headgasket. Its my daughters so its got pink but its all blue power on the inside. Lots of good info. Also do a search and read on the vipers, you could read for day's. Very strong sled. http://www.totallyamaha.net/forums/showthread.php?t=80244
SXRider7Hundo
Raise the needles, do a good once over, check w arm and suspension as mentioned earlier. Do pre season tune up, send shocks to pioneer for a good revalve then ride the snot out of it.
tippmannator
SXRider7Hundo said:Raise the needles, do a good once over, check w arm and suspension as mentioned earlier. Do pre season tune up, send shocks to pioneer for a good revalve then ride the snot out of it.
well said!! X2
LaPorte429 said:Yes the viper is "stronger" than the SXR for sure!
He uses an artic cat cover, "Found it laying on the road.''
Yamahahoo
TRUE BLUE SINCE 1980 said:He uses an artic cat cover, "Found it laying on the road.''
Very nice, that sled is certainly safe from theft, assuming the cover says "Arctic Cat" on it somewhere!
