bearing removal
Yamahasrx700
Channaho, Il.
Any one have a method of removing the bearing that sits behind the water pump impeller? I already have the cases split. It idles the water pump/oil pump drive.
Yep, you have to get the impeller off then take out the seal and then the clip-without damaging the shaft or case.
yep and them seals are a :o| in the azz to get out..learned last year.Second time around was better but still a lot of swear words going on and no broken window.....lol
Any one have a method of removing the bearing that sits behind the water pump impeller? I already have the cases split. It idles the water pump/oil pump drive. The shaft has a gear in the middle. The bearings have to come out before you get the shaft out. I am looking for detail.
No, the bearings do not come out before the shaft, they are pressed on to the shaft, you must remove the impeller,seal and clip to get the shaft with the bearings on it out.
