gears
780srxgeorge
michign
will the 97 v-max4 top gear the same as 98-01 sx chasseys,need to gear up for the 8t drivers. & 37-24 w/ 8t is pretty close 1.73to the 1.65 i have know. :yam:
i donot want to order one & be wrong! unless one of you guys have one that i can buy? a 24t top gear.thanks
no problem!
I got curious and did a little searching... none of the part numbers match up between the two sleds so I'm gonna have to say no on this one.
all right how about the rx-1 it's got a 24 will this work on my srx.i know that it is a hivo chain but what can i do there is no other choice.have to swich it all out.thanks
dang what the hay-hay :o| am i going todo?.need to gear up for those 8t drvrs.have to do some calling around & find a 36 bottom.thanks for the vice pro116 ;)! :yam:
I'm running 23/37 with 8 tooth drivers. Little loss on top, but good corner to corner. I think it's like 1.80 ratio if i remember.
thanks for the info ;)! but trying to keep the ratio down & around the low 1.70s.i have the 8bu's & thay are loaded to the max & don't want to over rev.i know it's going to do some a little rev.thanks ;)!
