Will a set of 1995 Skidoo Mach 780 triple 38mm carbs fit?
yes they will,we had a set on a 97 SX700 all we had changed were the mains,they are snug on the carb boots but will fit,we put a little bit of grease on the boots to fit them in ,then we made sure all the clamps were on
tight,all machz had the same cylinder spacing,so all years should fit,I
don't remember what we did on the airbox side,it seemed to pull more on topend and wanted to rev higher,but we never finallized the project like going on the dyno like we usually do, to see if the torque curve had changed much,we only used them on a few outlaw grass drags,then sold the sled and kept the carbs for other projects. good luck
hey thanks, im still debating wether to get a set or not, I have my 33's bored out to 35.5 already, and others here say it would only gain me a couple of HP, I thought it would be more then this on top end but if tha'ts all it gives me, im not sure what IM gonna do............
