Anyone know of any decent power adders that can be bolted on to the SRX. It would appear that, according to the forum at least, nothing aftermarket succesfully makes more power for the srx.
The list below is normally tagged by forumites as being a power loss or waste of money. Did yamaha do that good of a job of making the perfect sled?
Can
Reeds
Boost Bottle
Cold Air Intake
Reed Valves
Pipes
This list excludes of course trail porting and clutching.
Can
Reeds
Boost Bottle
Cold Air Intake
Reed Valves
Pipes
Yamaha had there homework done on the SRX as far power goes, not really much you can do to a stock motor other than porting it to make more power
I think there is head mod you can do but not sure others will chime in also
Squirt it with laughing gas,best bang for the buck.
Reed spacers do make about 1.5hp on the dyno but unless you find them cheap or make your own there not wort it for the price.
YAMMIEGOD3:16
I,LL GO DOWN YOUR ORDER.snopax said:Anyone know of any decent power adders that can be bolted on to the SRX. It would appear that, according to the forum at least, nothing aftermarket succesfully makes more power for the srx.
Can
Reeds
Boost Bottle
Cold Air Intake
Reed Valves
Pipes
CAN- NO
REEDS - NO
BOOST BOTTLE - NO
COLD AIR INTAKE - NO
REEDS - NO
PIPES - NO
I,LL ADD MINE.
CLUTCHING - YES
GEARING - YES
JETTING - YES
TRACTION - YES
SUSPENSION SET-UP - YES. 3:16 (yammie tony)
fusion: I like the NOS idea, but clutching for it would be a pia...
Yammie: Is there a better gearing combo for a trail runner? everything else is stock. 9 studs. Hauck clutch kit 41/49 helix
straight to the point as usual GOD..lolYAMMIEGOD3:16 said:I,LL GO DOWN YOUR ORDER.
CAN- NO
REEDS - NO
BOOST BOTTLE - NO
REEDS - NO
PIPES - NO
I,LL ADD MINE.
CLUTCHING - YES
GEARING - YES
JETTING - YES
TRACTION - YES
Can
Reeds
Boost Bottle
Cold Air Intake
Reed Valves
Pipes
Weird, you left out the two things that will give you a power gain.
And those would be?norwegian said:Weird, you left out the two things that will give you a power gain.
Trail porting and clutching.
tippmannator
the way i read his original post is that it was already understood that trail porting and clutching would give you power. the question seemed to be more geared around bolt ons. of course i could be way wrong
but i will agree with yamigod. the list you gave will only rob power. porting , traction, and clutching are the way to go for power gains on a srx
norwegian said:Trail porting and clutching.
I think he did include those two things, plus clutching does give increased performance, not power. Clutching gives better delivery / efficiency / use of the power it already has, which can be increased by trail porting.
tippmannator said:the way i read his original post is that it was already understood that trail porting and clutching would give you power. the question seemed to be more geared around bolt ons. of course i could be way wrong
X2 ^^^
snowcrazy
can yes reeds yes cold air yes i could pull more clutch weight with each mod so i say yes and still do all of the above if i get hook up hang on tight
snowcrazy said:can yes reeds yes cold air yes i could pull more clutch weight with each mod so i say yes and still do all of the above if i get hook up hang on tight
Terrible bang for your buck with those mods, an aftermarket can will lose hp most noticeably on top end because of the lack of back pressure! You will lose mph as many people can attest to.
I'm still not totally sold on the can losing hp just yet, some yes, but have had just as high speed #'s with can as stock, I think the bender performs well, and the hauck race growlers, you lose weight as well. weight is speed, especially with my big a.. on it.
fusion 69 said:I'm still not totally sold on the can losing hp just yet, some yes, but have had just as high speed #'s with can as stock, I think the bender performs well, and the hauck race growlers, you lose weight as well. weight is speed, especially with my big a.. on it.
You do lose weight, maybe 8 or 9 lbs, but you certainly do not gain hp, you will likely lose some. Many people feel as though they have gained power because it makes your sled sound more mean and faster: it is just a mental thing. If I remember correctly a member on here went back to their stock can and had an over rev on top = more power.
While weight does lug down the motor and therefore rob the hp it is making to a point, 8-9 lbs will not overcome the loss in back pressure from it being more lightweight, which will lose mph upstairs.
Rustman
lighten whats spinning and then make it all go in a straight line.
just run the best fuel you can....keep PV's clean and adjusted..make sure skid is tightened up and she will fly....
snowcrazy
all my mods are bender racing mods proven to run harder and quicker some like other peeps mods turk has lots of good tips im happy with my set up 14,000 miles never burned down new rings every 4000 mi and engine tear down every 2nd year so far it's all good and rode more than any other sled i have so it's up to the rider what makes ya happy
