Machinist needed
jabber800
Coniston Ont.
Hey guys, I'm hoping someone can point me in the right direction for a machine shop that can make up a couple splined shafts for me. I need replacements for my track dyno and dyno jet refuses to sell to me because I am not registered with them. Problem is setting up an account with them is worth more than the parts.
Any help would be appreciated!!!
Thx Dan J.
Yep it has been a pain. The shop I purchased the dyno from had told me they could get the parts and would order them for me. I guess they ran into a road block and could not get them either. Now I am strapped for time as I want to test a few sled set ups before the snow flies. Have you done any racing this summer?
none this summer, works been crazy. decided to put the 780 in my long-traveled trail sled and build a high rpm/compression 700 for racing. it'll probably be a while for that so I'll run the 780 on the grass this fall. hopefully have the 700 ready for ice
b+d machineing here in town should be able to help you out if you need to get them made. they have made shafts and gears for us before for vac truck transfer cases.
i can make them for you but probally looking for someone there close to you ...let me know if you have had any luck
