Is there a safe way to power up an 02 Viper gauge display / meter while still on the sled in order to check mileage on a sled that's not running? The motor is partially apart, and it's a std Viper/non ER. Thanks,
Ron
Ron
WIsnoRyder
I dont remember off the top of my head the wiring diagram on that harness. But all you can do is take a battery and find your positive and negative on your harness and see if it powers up. At minimum the backlight should come on if you supply power to the right wires and have it grounded properly.
