Broken Carburetor Part, replaceable?
mcarey
Colorado
Hello, First thanks ahead of time for the help...I have a yamaha 2002 sx Viper that has a broken piece on the middle carb. It is the white plastic 90 degree elbow piece coming out of the side of the carb, part of the air vent hose. Can this be replaced? Does it unscrew or do I have to take carb apart?
hopefully this is not redundant thread, I searched, but sorry if it is. Thank you.
Or buy some junk carbs with a good elbow. They are removable... Ive replaced them before on some of my other sleds.
A small piece of brass tube (hobby shop) inside / at the same hobby shop small piece of plastic tube to fit over the brass and but up against the fitting and epoxy the whole deal up with JB Weld.. Works Great!
you might be able to find a similar sized brass 90* fitting at the hardware or hydraulic shop and drill out what you have and epoxy(jb weld) in the the replacement piece. Another thought would be to contact SUDCO out of California as they import all kinds of parts for Mikuni carbs.
