Live2Ride
- Nov 24, 2003
I was wondering if anyone knows the step by step process of bleeding the coolant system? Also I was wondering if anyone knew all the torque specs for the bolts on the heads, jugs and powervalve hex heads?
Brad
- May 23, 2003
toruqe specs/cooling system
personally i would buy a service manual from the dealer that is what i did it will give you the specs for every peice on your sled,and procedure.that way you always have all that info on hand
didnt i just aanswer these questions.....you have to pull the seat to bleed the air....crack open the bleeder unitl the antifreeze comes out, then top of the system....run the sled and let kewl...then bleed again. The head and jug specs are in the tech area all the other smaller bolts ar 7 to 10 ftlbs http://www.totallyamaha.com/snowmobiles/aaTECH/Simple_Specs.htm
