here is the verdict on the re-machined/coated PV's
Howden ,Manitoba,Canada
I took out the PV's for the first time since last season when I put the PV's in that I got back from ya-ma-head(mr powervalve)
The coating looks like it doesn't hold up on the underside probably from the exhaust heat,but from there all around to the other side is good.It only took me like 1 minute each to clean with a scotch pad with gas.There was no major build up of gunk like there usually is on these.I am very happy about this and the best part is the SS head on these..they are perfect,the valve just slide's right off the cable..so pull thru's are a thing of the past.
Take a look for yourself... ;)!
good work Rich....
Blue,
Does that graphite just go on like paint? Is it something that's going to wear off really quick? Or will it stay for a while ? I've got some Comet liquid graphite in the shop. Wondering if it's basically the same stuff.
