Guy going from my stock 9T drivers to a MM 8T, does anyone have measurements on these? I found this online, but do not know if its accurate. I believe I would be going from Figure A to Figure B, if this is correct let me know please.
thats odd that the venture would have the outers 2mm further. what track are you going with?
just measure distance between the inner and outer drive lugs on the track. cant see where 2mm is a make or break unless your new track requires it.
the important part is the axle ends to the drivers measurment.
as i mentioned in the pm, look for the arrows on the drivers and keep them all the same way in relation to the hex shaft.
I am going to run a challenger track, make any difference? I was thinking maybe the MM ones were bigger?? Yes no?
sleddineinar
That is correct fig A to fig B. As far as the track goes it doesn't matter unless you trying to put a different pitch on... Anyway the lugs inside the track are all pretty much the same. The C to C is what I go by when spacing the drivers.
