MikeSr
Are all the SRX 700 cases the same no matter what the year? I see one part number for the 98 and 99s, and a different part number for the 2000 - 2002.
thanks
thanks
NO 98 and 99 are not the same as 00-02. The difference is a single vs a double bearing groove at least. There may be other things as well.
viperking
viper cases are the same as 00-02 srx cases though
mopar1rules
norwegian said:NO 98 and 99 are not the same as 00-02. The difference is a single vs a double bearing groove at least. There may be other things as well.
the bolt holes for the pickup coil are in slightly different spots.
MikeSr
There is a brand new case on e-bay which posted today. I contacted the seller and it is for a 88 or 89 (which it didn't specify in the add). There is a buy it now price on it for under $200 if anyone is interested.
DARV
Life Member
cases
i have a set that have been cleaned with bearings for water pump installed that i do not need i would like 150.00 plus shipping or BO it is foe 98-99 years
mrviper700
VIP Lifetime Member
MikeSr, you can alot of times repair a case if you have the usual pressure cracks in the bottom section from debris getting smashed in there via the connecting rod from a burndown/blow up. I clean them very well with lots of brake clean and then tig weld the crack. You just have to weld slowly to avoid warping the case half. Clean off the inside with a sanding roll and your good to go.
MikeSr
thanks for the info guys.
Mike
Mike
