Hey guys, noticed the rear of the track is pitched of the ground. Is this normal or should the whole track be on the ground?
livewire_101proof
this is normal, when u throttle it it will rock back on the rear. The only ones who usually worry about getting everything to set flat are looking to do alot of drag racing.
Mine have always sat flat on the ground. My SX sits flat and so does my XL-V. Both have good transfer too. snopax how is you steering while you're on the throttle?
Read this if you haven't already.
http://www.totallyamaha.net/forums/showthread.php?t=34503
It will explain the proper height for the track at the rear of the skid plus everything else you may want to know about the skid
livewire_101proof
X2 especially if u are having handling issues them steps will cure it for u
