stillen
- Jan 25, 2004
I got a 2000 SX-r 600, Can anyone tell me at what RPM is the clutch suppose to engage? Its a bone stock sled.... Just FYI, Mine isn't engaging until like 3800-4000 rpm's. belt is broken in with less than 300 miles on it....
sledderbob
Book spec 4200 + or - 200 rpms yellow/green/yellow spring
98srx6
Stillen you should be okay with that engagement, if you put a new spring in your primary i bet you would see that engagement go up.
BlueIronRanger
- Nov 26, 2003
any more than 4000rpm and you will spin the track way too easy off the line, especially if you still have the stock yoko track on it.
