Low viper windsheild
romig
pa
Where the heck can you find a low windsheild for a viper I DO NOT want a blue one or one with graphics I just want a plain clear or smoked low windsheild
take your stock one an cut it down..just get a pattern first an you would think the end result was a factory low windshield..cheap an easy
i heard of people marking it out then taking a small rotary tool to cut it..gives it a nice clean cut..i also heard of pp using a sharp set of tin snips, but not as clean of a cut but u do cover it with the black molding again so maybe it would be okay..
ive done it before, just cut it a little higher than your mark then used a die grinder to dress it up and smoothed off all the rough edges, and a little piece of trim around the edge covers it anyways if you want.
I cut mine with just a cutting wheel and then switched to a sanding/grinding wheel do smooth to my marks. Worked good... i resued the same trim and just cut one end off a little.
Low Windshield
Try royaldistributing.com. There in Canada. They have a 9 1/2'' without graphics for $59.99.
