so i got 1999 yamaha srx 700 n want to put better track on it. was wanting to know if 1 1/2 track will fit without changing drivers? i removed the heat exchanger protectors already and measured it and seems like it will fit perfect... any info on this guys? thanks
Will fit once protectors are out.
tippmannator
00sxrjoe said:Will fit once protectors are out.
X2. you should be good. any bigger and you will have to step down your drivers.
edunn69
You will have to remove the tunnel protectors also or it will hit.
ottawaair
dont stud it.
