i want to run a 14 x128x 1 inch hacksaw on my srx with a m10 what will it change from 15 wide to 14 wide. will i have any problems at all. it will be a little narrow.
xt_gt
just make sure your outter wheels don't ride off the track.
other than that, you shouldn't have any issues. i cut a 15" track to 14" for my phazer. 1/2" off each side. take your time cutting. fairly simple.
^ ^ ^ ^ ^ ^ ^ ^xt_gt said:just make sure your outter wheels don't ride off the track.
What he said. I've run a few 14" wide tracks and the only issue is the outer wheels. Grind a few mm. from the outer wheel spacers to bring them in a little bit and you'll be good to go.
thanks boomer I will have to make sure the wheels are narrower. what wil the smaller width feel like and different than the 15 wide.Boomer said:^ ^ ^ ^ ^ ^ ^ ^
snoprokidf6
i'm running a 14 in wide track now and no problems, ran it on water all summer and didn't have any issues
